After some time i tought its stabile enough to make some decks and start using it again. ATM it doesent load anything cinepack, MJPG or even JPG. Decks dont work either, i only get the preview image but noting loads. The preview in the browser doesent show anything too.
Also noticed that randomly chanels stop working, sometimes im down to one working chanel until i restart the programme.
XP SP1
resolume doesnt load any files
continuity-B
probleme solved
Win WP/ SP1
Nvidea 5700
1Gb ram
P4 2.8
Problem
-All Files dont load when drag and drop
-All Files dont show the preview in the browser
-Decks will load only previews and wont load into chanells
Solution:
A fresh instal of the graphic drivers.
When i was experiencing the problems above, i tryed to switch the output screen on and off, resulume was so qick to do that, that i suspect it was not changing anything. The usual "blackout" that glichy break that happens to the interface when the output screen is enabled just didnt happen.
Nvidea 5700
1Gb ram
P4 2.8
Problem
Solution:
