Arena 7 - Opening comps on other machine causing double resolution
hikita
Post by hikita »
Hello!
I am using Arena 7 on a Mac and a Windows computer.
I created a composition with a resolution of 3840 x 2160.
When I open the file on my Windows computer it has the double resolution (7680 x 4320)
Why is that?
Thanks for help,
Hendrik
Re: Arena 7 - Opening comps on other machine causing double resolution
That's because the other machine has a different texture size support and composition loading is broken a bit ;)
Will be fixed in the next release.
Setting the composition size back to the original should get everything back into order.
hikita
Post by hikita »
Hey Zoltan, thanks for the answer.
Unfortunately setting back the composition size does not fix this problem completely, because all clips also takes over the double resolution. So that is something I have to reset per clip :? .
Until we can bring the fix out, try selecting all clips, right click on the selection, in the contextual menu choose Resize - and one of the options to get the clips back into shape.
