Resolume Maintenance: 7.0.3 & 6.1.4 Released
We're in full on maintenance mode here at Resolume HQ to make sure v7 becomes just as stable as v6 as soon as possible. Unfortunately a new major release (like 6.0.0 and 7.0.0) usually comes with a few bugs because they contain a lot of new code and have not yet been road-tested as much. Please keep sending us your feedback on mail@resolume.com and send in crash reports so we can fix them as soon as possible. This is our top priority right now.
Foto: ALAMY
Foto: ALAMY
Resolume 7.0.3
Resolume 7.0.3 fixes a lot of bugs and some crashes that were occurring, especially when switching decks. Denon StageLinQ network connection is now much more robust and compatible with the Prime 4. This version is compatible with FFGL 2.1 plugins which has a few improvements so plugins can be made more user friendly. All our macOS installers are now notarised by Apple to ensure a smooth installation on macOS 10.15 Catalina.
Resolume 6.1.4
While working on bug fixes for v7 some bug fixes were easy to transfer to v6. So here is an even better version of good old v6: 6.1.4
Download
Checkout the download page or select "Check for Updates..." in the Avenue or Arena menu and it will self-update.
Hotfix Monday Sept 30th
If Resolume could not startup on your Windows computer with an AMD video card then please download again. This issue is fixed in Arena 7.0.3 rev66005 and Avenue 7.0.3 rev 65698.
Resolume 7.0.3 Bug Fixes
#13243 Random crashes switching decks
#13171 Crash trying to load jpeg image which is larger than your GPU max texture size
#12376 Possible crash in Advanced Screen setup doing undo-redo
#13142 Crash trying to load extra effect which has gone missing since load
#13144 Crash opening media manager with a deck named with non english characters
#13244 Stop motion effect on a layer crashes on clip launch
#11475 AJA io 4k not showing up as output
#12100 AJA Kona losing input can make Resolume freeze
#13161 Player index selection not working properly with Denon prime 4
#13162 Player 3 and 4 on the prime 4 are not updating the play position
#13183 Loading same track on another Denon player takes over the clip already playing
#13276 Denon Players with their clip targets set to "Composition Determined" don't actually do that
#12767 Arena does not always pick up playing Denon tracks on Windows
#13290 Stagelinq connection to Resolume can make Prime 4 player lag
#12233 Midi output is sent twice on Windows
#12359 File browser not updating correctly when renaming files & folders on the filesystem
#12409 Show in Finder/Explorer & Show in File Browser disabled for Persistent clips
#12423 File order is wrong when dragging from Explorer
#12459 Panning while dragging a slice leaves slice in original place
#12512 Renaming deck to empty name, makes other deck disappear from list
#12553 Clips without alpha have Alpha button enabled and Alpha type showing in video track properties
#12575 Loading 'Default' effect preset sets effect blend to B&W
#12747 Recordings don't show up in Files panel if you have recording folder selected
#12804 Update NDI dll to latest patch release
#13111 FFT input needs a 6 dB boost to get the same level as in version 6
#13134 Spinners in Advanced Output Edit points mode no worky
#13135 Default keyboard shortcut preset gets overwritten on every startup
#13137 Selecting a persistent clip with an underlying clip, the underlying clip is selected on second click
#13143 VST plugins are not loaded form Extra effects folder
#13147 Edge detect on Mode=1 behaves differently on windows than on V6 and mac
#13157 Layer auto pilot selection is not showing when importing an R6 composition
#13160 Parameter display value is not visible properly in 7
#13168 Strobe effect behaves differently than in R6
#13170 connectSpecific Shortcuts are no worky after import from V6
#13172 Clip alpha type is not remembered on composition re-open
#13173 Slice background and outline draw at different positions when zoomed in
#13175 Re-ordering decks can fail if you have closed decks
#13178 Moving reveal effect from clip to Group breaks External audio input Seed source
#13180 Parameter set to play once and hold doesn't resume animation when loading a preset with loop
#13186 Clips with SMPTE and Denon don't reset the clip duration when the video track is replaced.
#13191 Can't set position, rotation and Anchor back to 0 (default) via 1 DMX channel
#13199 Changing Spiral Direction can make the spiral angle jump
#13210 Opening composition on another machine that supports different texture sizes, changes the composition resolution.
#13214 Playing DXV HQ with Alpha and NDI output in ASS, makes DXV clip flash
#13216 Group # becomes visible when hiding crossfader
#13220 Opening media manager with specific compositions can crash Resolume
#13221 Basic slider with Envelope activated does not display correct value in textbox
#13245 OSC /composition/layers/1/clips/1/transport/position/in and out no worky
#13250 Column names and colours not reset when creating a new deck
#13302 SMPTE input numbering mixed up in French UI translation
#12146 Do not recursively search FFGL .bundle folders
FFGL 2.1 in Resolume 7.0.3
We've made some improvements to the FFGL plugin SDK so plugin developers can make their effects more user friendly. Full details and sample code are on GitHub. https://github.com/resolume/ffgl
+ Added support for embedding a thumbnail inside the plugin. See the "CustomThumbnail" example on how to expose your thumbnail.
+ Added support for File parameters. The plugin can create a file param and specify what extensions it supports, the host then has enough information to show a file chooser dialog with active extension filtering.
+ Added support for toggling parameter visibility.
+ Added support for parameter visibility events. (A plugin can now toggle visibility of a parameter on the fly)
+ Reintroduction of Scoped bindings. (Removed unsafe resetOpenGLState function, use the ScopedBinding classes instead)
+ The Module Definition File is no longer required on Windows.
+ The SDK no longer adjusts any textures to use GL_CLAMP_TO_BORDER.
+ Renamed CFreeFrameGLPlugin class to CFFGLPlugin. Plugins now need to inherit from the CFFGLPlugin class.
+ Fixed param value being normalized when ranges are involved. Values going between host and plugins are now the actual values, not the phase within that parameter's range.
+ Fixed some internal SDK warnings, convoluted implementations and inconsistencies in namings. (Most notably the quickstart module now uses the same conventions as the ffgl and ffglex modules)
Alley 2.1.3 Bug Files
#13122 Possible crash on shutdown
#13271 Convert Audio checkbox not working when multiple files are selected
#13138 Removing a conversion item from 1 source and multiple outputs, removes all conversion processes for file
Resolume 6.1.4 Bug Fixes
#12374 BlackMagic Decklink outputs freeze after 10 days
#13290 StageLinQ connection to Resolume can make Prime 4 player lag
#11892 Clip effects are bypassed on layers with width or height set to 0, layer plays with full size
#12445 Disabling/enabling Spout leaks GPU memory, eventually Resolume stops responding
#12446 Setting a cue point again doesn't work
#12496 Recolour effect does not respect alpha
#12575 Loading 'Default' effect preset sets effect blend to BW
#13018 'By position' target Deck shortcut opens closed deck's clips
#13082 Play/pause on group layers doesn't work
francoe
Re: Resolume Maintenance: 7.0.3 & 6.1.4 Released
Post by francoe »
Hey, I'm the only one who love maintenance releases? C'mon you all, show some love! :D
Note aside: 6.1.4 Any change related to h264 management? Updated yesterday before a gig and haved several issues with usual clips (I still haved no time to test if was on arena side).
francoe wrote: Mon Sep 23, 2019 07:27 Hey, I'm the only one who love maintenance releases? C'mon you all, show some love! :D
Thanks Francoe ;-)
francoe wrote: Mon Sep 23, 2019 07:27 Any change related to h264 management?
We have not made any changes there but please do sent us the file(s) if they do not play correctly.
francoe
Post by francoe »
Thanks Bart, is good to know. Don't worry, I wil try to figure out what happened.
asjer
Post by asjer »
So how's it running on macOS Catalina, is it stable? Not sure if I should upgrade to Catalina just yet...
asjer wrote: Thu Oct 10, 2019 16:02 So how's it running on macOS Catalina, is it stable? Not sure if I should upgrade to Catalina just yet...
Runs nicely for me on Catalina.
Keep in mind Catalina is 64 bits only now, so you might not be able to use your other programs.
asjer
Post by asjer »
That's good to hear! Haven't thought about the 64 bits only, I'll have to check all my programs to be sure. Thanks for the tip.👌🏼
