Hi, I have put my laptop in repair service and might not get it back before I go overseas for a few shows. I have the iPad Pro 12.9", and was wondering if there's ANY way to actually use that as my machine to perform (only the iPad with no other computer).
I have an APC40 II I can probably hook up to it as a controller but is there even a software version that would run on the iPad? And will the iPad specs be enough?
CPU: 2.26 GHz dual-core Apple Twister
GPU: 12-core PowerVR Series 7XT
RAM: 4 GB LPDDR4 RAM
Very doubtful, but still figured it was worth asking around. Thanks!
Running Arena on Ipad Pro only
Re: Running Arena on Ipad Pro only
Don't be afraid to say "hell nah, stoopid." I can take it
ianscott1024
Arena is made for x86 machines iPads are not of the same system architecture and I doubt resolume will support it ever.
There are other VJ apps I believe that do run on iPads
