Resolume to Capture -> NDI or CITP
Kristey17
Post by Kristey17 »
Hi averyone.
I try connect the resolume arena to Capture.
My network its ok and I can see the video servers in Capture (Media Tab).
Im test with:
  • CITP: Arena -> Syphon -> CITP Tools -> Capture
    NDI: Arena -> NDI -> Capture
My problems start with the resolution.
My composition in resolume have 1280x720, my virtual screens in Resolume have de same resolution 1280x720.
However the resolutions I see in Capture are completely different:
  • CITP: 640x480
    NDI: 640x360
I can understand why the resolutions are diferents.
In CITP changing the resolution in Resolume is indifferent, what I see in Capture is always 640 x 480
In NDI any resolution below 640 x 360 is accepted and Capture adapts automatically.
Anyone can help me please?
Thank you so much
Chris
Re: Resolume to Capture -> NDI or CITP
Does your Capture software support input/CITP image size larger than 640 x 360?
Bassindaniel
Post by Bassindaniel »
Try use OBS or built in recorder on NDI TOOLS 4 - studio monitor
Kristey17
Post by Kristey17 »
Bassindaniel wrote: Mon Oct 14, 2019 07:35 Try use OBS or built in recorder on NDI TOOLS 4 - studio monitor
Can’t understand your suggestion.
Can you explain more?
Thank you 🙏
Jgrover
Post by Jgrover »
Pretty sure you have to change the NDI resolution in Capture.
You may have to use multiple slices at low res and combine them to a higher resolution in Capture.
