How do I record seamless loops?
cizkek_
Post by cizkek_ »
Hello everyone. I'd like to record seamless loops, synced to bpm in resolume. Is there a way to do that?
Currently I try to do it like this:
1. Pause everything
2. Set up clips to play once and clear
3. Set up bpm and loop points
4. Press record
5. Press play
6. End recording
As you can see it is a lot of steps. What I really would like to avoid is having to adjust clip in and out points, so the clip recorded loops perfectly. As you can imagine, it gets really annoying when the mouse keeps missing that perfect point especially during a Live performance.
Is there a feature to avoid this? Or a better workflow?
I wish that there was a "Record x Seconds/Bars/Frames" option.
Thank you.
Re: How do I record seamless loops?
Recording seamless loops from looping clips is not possible in Resolume currently unfortunately.
I personally create all my loops from non-loop content in AE.
