Problem: Can Resolume send current column number to TouchOSC? If so, how?
I can use something like /composition/selectedcolumn "+" 1 from TouchOSC, which is received in Resolume, and does nothing. How can I get the correct info to Resolume
Secondly, How can I get the SELECTED COLUMN information into TouchOSC?
I know this is a bit vague, but I'm stuck, and have gone through more webpages and YouTube videos which haven't helped. LOL.
Any help at all is EXTREMELY appreciated.
TouchOSC and Resolume - Getting/Sending Column Number
rockwithrev
Re: TouchOSC and Resolume - Getting/Sending Column Number
You can ask Resolume if a column is selected by sending a string question mark to addresses like: /composition/columns/1/selected
You can also ask about all the columns in one message by sending ? to: /composition/columns/*/selected
This will return all column selected states.
The selected column might not be the one where clips are playing though.
I you'd like to launch the clips of the previous or next column, you can use the /composition/connectprevcolumn
/composition/connectnextcolumn
addreses.
https://resolume.com/support/en/osc
addreses.
rockwithrev
Apologies for clarification, but is sending the query:
/composition/columns/1/selected "+" ?
/composition/columns/1/selected + "?"
or some other form?
On a completely side note, if anyone has done this with TouchOSC, I'd really like to update a label with the value returned. Anyone know if that's possible?
Again thank you for the help! Thanks Zoltan!
or some other form?
The query should be an OSC message to the address
with a String argument:
I've checked touchOSC, looks like the version I have doesn't support sending strings
But your template should still follow changes coming from Resolume on the specific addresses fro the specific columns.
basic first
Have to enabled osc output inside resolume and are the ports correct? did you get any info from resolume to your tosc (like moving a fader)?
~Berlin~
~Berlin~
