Help - Sending MIDI from Bandhelper
rockwithrev
Post by rockwithrev »
Using a program called Bandhelper which can send midi (raw hex or LSB, MSB, Program Change). Is there any documentation as to what values to send to each mapable "thing" in Resolume? For instance, what MIDI value I would send to Resolume to select a column or deck?
Any help is appreciated!
Re: Help - Sending MIDI from Bandhelper
You can use any note or CC in Resolume to control things: https://resolume.com/support/en/midi-shortcuts
