Slice Control (new feature request...)
projectneptune
Post by projectneptune »
Hey there, just a thought, it would be really useful to be able to have midi mappable control over slices when the Advanced Output window is not open. There are often times when I need to switch mask/routing/slice configurations in the middle of performance, and having to open up the advanced output and click each necessary box can be a little tedious, especially if a transition needs to happen quickly. Wondering if a shortcut/keypad could be an option as a tab that sits next to sources?
Loving the updates to 7 so far!
Re: Slice Control (new feature request...)
Have you seen the Slice transform effect yet?
https://resolume.com/support/en/transfo ... -transform
You could use it to quickly change your looks / slice outputs.
This video explains the potential in Slice transforms:
projectneptune
AMAZING!!
I hadn't see this yet.
This is exactly what I need.
Best,
Max
