BM Webpresenter is glitchy on high res....?
Yuckfou157
Post by Yuckfou157 »
So I keep forgetting to post this ,but I have this for over a year now so it's time to see if there's a solution.
I use a BM webpresenter ( https://www.blackmagicdesign.com/produc ... bpresenter) for capturing a camera or SDI source into R6 which works flawlessly except, whenever I choose a resolution higher then the lowest (like 360x480@25fps) I get glitches all the time, like the stream isn't stable.
Stupid thing is sometimes after a while with everything up and running it works fine at 720, but then again the glitching start and I need to use the lowest possible to have it flicker free.
In other software like OBS it works without a problem, so my guess is it's somewhere between the BM and Resolume, if needed I'll send you guys my device for testing, but as said, I forget to post this multiple times, so I'm not in a hurry :mrgreen:
Re: BM Webpresenter is glitchy on high res....?
Looks like this one is using the OS drivers to appear as a camera source.
We don't have a copy of this device, so we can't test it unfortunately.
Are you using this on mac or windows?
Do you have the latest drivers for the device?
Yuckfou157
Hey Zoltan,
Sorry missed this for a while as I'm not so much here the whole time, uhm it's on windows, and there's not so much as new drivers but I am using the latest, give me a week or so to test with Arena7 after Friday and if the problem persists I'll mail HQ about sending mine in so you guys can try fixing it at HQ alright? :)
Yuckfou157
Quickie update; as it didn't happen in OBS it does in google hangouts so my guess is that the problem is inside the device, not the software and I'm arranging a repair with the seller now.
