10x NDI beamer
Filipsz
10x NDI beamer
Post by Filipsz »
Hi everyone,
Going to do next:
Server with 10Gb network card
Gcard 1080 or better
Optical connection between netcard and utp hub
Hub 10gb in/1 gb cat 6 out to deltacast neo n2h, hdmi to beamer
This must work, what do you think?
Any unexpected limitation, e.g. edgeblending?
Or standard behaviour as normal output?
Synchronisation?
Many thanks for any note
drazkers
Re: 10x NDI beamer
Post by drazkers »
This will 100% not work for edge blending or needing the projectors in sync.
If gaming cards sometimes go out of phase, that rig for sure is.
Filipsz
Re: 10x NDI beamer
Post by Filipsz »
Sounds logic, but did you test it? Edgeblend via ndi?
With this deltacast boxes?
What if this boxes are synchronized..
Or the only synchronization is on the GC?
Not in resolume, if ndi output?
So many questions..
drazkers
Re: 10x NDI beamer
Post by drazkers »
These boxes don’t take genlock. How would you sync them?
Re: 10x NDI beamer
^ With magic and love
Filipsz
Re: 10x NDI beamer
Post by Filipsz »
So it works!
Already tested with 3 beamers.
A bit of nerves but its done.
Compo 5760x1080
3x deltacast neo n2h
1 utp from arena server
1 switch 1gbit
In 14 days going to do 10 beamers, will work, surely.
drazkers
Re: 10x NDI beamer
Post by drazkers »
Take a video of it strobing white. Or hard cuts.
Even fast moving content should show seams.
Filipsz
Re: 10x NDI beamer
Post by Filipsz »
No latency (almost)! 3 frames max
Perfectly smooth, videos, camera, everything as it should be.
No more problems with multiple outputs.
Filipsz
Re: 10x NDI beamer
Post by Filipsz »
No, its ok. Transitions, everything. Really. I know what u mean and it itsnt there.
Filipsz
Re: 10x NDI beamer
Post by Filipsz »
Btw its a movie picture.
If there is anything glitchin, u should see it
Otherwise its microseconds, not mili and its ok
