Debouncing
chq
Debouncing
Post by chq »
a debouncingoption would be great.
Greetz Chris
Re: Debouncing
Sounds great!
What would that do?
He2neg
Re: Debouncing
Post by He2neg »
Zoltán wrote: Wed Nov 06, 2019 12:26 Sounds great!
What would that do?
+1
:lol:
~Berlin~
Re: Debouncing
I don't know anything about debouncing.... but I really like it!
+1 from me! :P
chq
Re: Debouncing
Post by chq »
:roll:
Debouncing means, that for example a clip would not be triggered again, when this clip has been triggered max x ms before. Therefore there could be a slider (0-1000 ms) for example.
Greetz Chris
Re: Debouncing
may you describe the use-case in which you would uses such a function?
chq
Re: Debouncing
Post by chq »
For example when a clip should be triggered by motion and two PIR-sensors has been installed, because of fail-safety.
Second example is an installation with bouncy push button switches.
When it's in advance clear, that there will be no need to trigger faster than 1000 ms, then this is a welcome option in the eventindustry, when Resolume is used as a mediaserver.
Greetz Chris
Re: Debouncing
Setting the clip playModeAway to continue from last position would probably help a lot with this: https://resolume.com/support/en/video#playmode-away
He2neg
Re: Debouncing
Post by He2neg »
Ahha... Now i know what i want...debouncing ;)
Its kind of the play ahead solution but also not....
I had a corparate job and i wanted a playmode:
When i click it the clip starts from the beginning, but then it cant be stoped till the end... so i cant excidently start it again.
Ofc you just pay attention and dont click, but a fool proof safety also would be nice...
The Problem to play ahead or realativ pick up was that i couldnt start it from the beginning easy but had to "reset" it somehow when i preview it before the show...
Soo Team Resolume may understand now what i would like to have and it may be called debouncing.
~Berlin~
Re: Debouncing
What would that do?
