Play sequence of clips once
benoitvm
Post by benoitvm »
I found no way to configure the layer Autopilot so that all clips in the layer play consecutively only once.
The >> layer autopilot button creates an endless loop of the layer sequence.
The workaround I found is to set each clip autopilot individually to "play next clip" and "do nothing" for the last one: is this the correct way to accomplish this ?
Re: Play sequence of clips once
Set layer to auto and then set your last clip to do nothing. This works for me in Arena 7
