Arena 7.0.5 - Preferences - Defaults
Holm
Post by Holm »
Dear all,
Arena 7.0.5 takes over the settings for "default video clip play mode" not.
I set "play once and hold", but each one video that I insert is played in the loop.
What is wrong?
Thank you
Holm
Re: Arena 7.0.5 - Preferences - Defaults
check our applications preferences menu under "defaults"
Holm
Post by Holm »
check, any playmode is accepted, except "play once and hold". If I set this as the default, all inserted videos run as a loop.
Hmm, indeed play once and hold default is not respected when importing new clips.
We'll look into this!
nickbeardo
Post by nickbeardo »
this is still an issue in 7.1.90 rev67353 (PC) - i've set my defaults to play once and hold - yet whenever i insert a video its set to loop!
zveerz
Post by zveerz »
How can this issue can be fixed?
Im using 7.13.1 rev16350
and this is still a issue.
