Soft Edge Help
projectneptune
Soft Edge Help
Post by projectneptune »
Hi There,
Trying to get control of my edge blending, and I am curious when I enable soft edge in the advance output window the bottom edges of my output get feathered instead of the left and right edges. Is there a way to change which edges get feathered for blending?
Re: Soft Edge Help
Which version of Arena are you using?
projectneptune
Re: Soft Edge Help
Version 7.0.5
Re: Soft Edge Help
Could you post a screenshot our your current Input slice layout?
also: https://resolume.com/support/en/edge-blending
gpvillamil
Re: Soft Edge Help
Post by gpvillamil »
Yeah, I'm seeing this too.
