The LK overlay chances black for the channel thats underneed.
Can I also use another colour for this ?
Like using a green or blue screen.
						LK overlay.
				beamlicious
				beamlicious
from the resolume manual:
						Autotransparency (T)
With autotransparency one colour is made transparent. Resolume automaticaly picks the colour, it takes the first pixel in the top left corner of the image.
Note that only one RGB colour value is made transparent. For instance colour r128 g128 b128 (gray) thus colour r129 g129 b129 is not transparent. Although your eyes won't see the difference between those colours. So it apears as if the autotrancpacency is not working properly. Therefore make sure you use autotransparency with footage that has very flat colours. This works best with flash movies with a flat background colour.
				beamlicious
