R6 Transport in/out points don't copy with composition
aaronop
Post by aaronop »
First time poster, hopefully this isn't something covered a ton but I couldn't find anything about this -
I'm using Arena 6, though I had the same issue with Arena 5, not sure if this is addressed in 7.
I often use longer clips and set up my composition with the same clip in multiple slots but with the Transport In/Out points set to different sections to create shorter loops from a longer clip.
When I copy a composition from one computer to another it doesn't seem to retain the Transport in/outs, just resets to playing the entire clip from beginning to end. Is there another file I need to copy over to get this transferred? Or does this just not copy over and I should stop working this way?
Re: R6 Transport in/out points don't copy with composition
Which Arena 6 version are you using?
