Clip Transport, BPM + - , mapped to controller chaos
media resole
Post by media resole »
In the clip transport controls, when I map the BPM + - to a dial on the original APC 40, the clip both speeds up chaotically and the vid goes out of sync w/the audio, then it resumes in slow motion. It doesn't do this if I use my laptop's trackpad to change the bpm in the clip's transport controls.
Thank you in advance,
Arena 7.0.5
Computer Specs:
MSI
Intel I7 7700HQ CpU @2.8 GHz
16Gb RAM
64 bit
Windows 10 Home
Graphics Card:
Nvidia GE Force 1060
Re: Clip Transport, BPM + - , mapped to controller chaos
Is your clip DXV3?
media resole
Yes, these are DXV 3 clips.
Which Ableton mode is the APC set to in the midi preferences?
How is your shortcut set up?
Does the midi input from the APC in the Midi inspector look like continuos values?
media resole
I am going to have to do further tests to make sure I answer your questions. I can answer by next week.
Thank you for the reply/interest.
