ShaderToy to FFGL (FFGL FX, FFGL sources, Win x64, 6&7)
niceolum
Post by niceolum »
.dll Win x64
for Resolume 6 & Resolume 7
All dlls were created for my own use, tested and work on nVidia GeForce GTX 1070.
Example some FX
Example some sources
He2neg
Re: ShaderToy to FFGL (FFGL FX, FFGL sources, Win x64, 6&7)
Post by He2neg »
Thanks for sharing... :)
BUT be carefull fellows, First test this stuff.
Plexus 3D Carshes my System when tuching the "Layer" Controll of the Source.
The other sources i also quickly run and had no crashes ;) Still awsome from you to share this work
~Berlin~
edwin
Post by edwin »
And also please check the original license of the Shaders from ShaderToy, often they are quite restrictive and not allowed to be distributed or used for commercial purposes.
edwin wrote: Wed Dec 18, 2019 17:41 And also please check the original license of the Shaders from ShaderToy, often they are quite restrictive and not allowed to be distributed or used for commercial purposes.
<3 <3 <3
EC from BE
Post by EC from BE »
Looks amazing, I feel bad I'm on a mac right now! ;)
weird_design_studio
Post by weird_design_studio »
How do I install the new sources on Arena 7?
I tried putting the .dll's from the source folder into "C:\Program Files\Resolume Arena\default\Presets\Source" but that didn't work
Try putting your dll files to Documents/Resolume Arena/Extra effects folder, and restart Resolume.
TruthC
Post by TruthC »
Hey,
Great FX, thank you.
I've done this for the first time too. How do you get the external shaders to show up in subfolders instead of listing each one? If that's not possible then how do you organize them? Having folders & subfolders would be very useful. Otherwise the list becomes too long.
Indeed having more options to organize plugins would be great!
Meanwhile what you can do, would be saving your effect presets with specific tags in the preset name, then use the search function to filter the list for the tags.
