Anyone else problems with the new Catalina update?
EC from BE
Post by EC from BE »
Shaper source crashes Resolume 7 every time on two different macbook pro's that got the update.
Also, some very small freezes (with simple line sources even) on a brand new macbook pro 16 inch with 8GB videocard
Re: Anyone else problems with the new Catalina update?
EC from BE
Seems they are talking about 10.15.1 there, the new update was the 10.15.2
Pete
Post by Pete »
I also hv problems with Arena 7.0.5 after clean install macOS Catalina 10.15.2.
Any solutions?
EC from BE wrote: Sat Dec 14, 2019 01:26 Seems they are talking about 10.15.1 there, the new update was the 10.15.2
Yeah, the crash stack they have is the same as with Resolume on 10.15.2.
OSX 10.15.0 should not have the issue.
EC from BE
Solved for me after the Resolume 7.1.0 release!
Yes, this should be fixed in Resolume 7.1.0. indeed.
EC from BE
GPU activity is still almost always at 100%, same with Touchdesigner.
Apple is looking into this, I have been more then 1 hour on the phone with support (for the 4th time)
They made me install a program to collect data and I did send them the result, will keep you guys updated..
