DJM-900NXS2 mixing table outputs
sefreso
Post by sefreso »
Hello,
Can someone tell me which output of the DJM-900NXS2 mixing table is best to use so that I can use the external FFT in resolume?
Here is a good picture of its back sockets :
And here is the documentation : http://docs.pioneerdj.com/Manuals/DJM_9 ... al/?page=2
I am wondering whether it's better to use the RETURN outputs or MASTER 2 or REC ?
I am using a Focusrite 4i4.
Thanks in advance!
AdevProjects
Re: DJM-900NXS2 mixing table outputs
Post by AdevProjects »
For RCA you could use either Master 2 or REC depending on if you wanted the mixer master volume control to affect the fft.
The RETURN is an input into the mixer.
The Master 2 audio is the same as the Master 1 XLR outputs.
The REC output is the Master audio but pre the master volume knob + limiter.
Hope this helps!
sefreso
Post by sefreso »
I meant SEND instead of RETURN.
Could the SEND be used in case I only have XLR cables?
Thanks. This helps a lot!
AdevProjects
sefreso wrote: Fri Dec 27, 2019 15:18 Could the SEND be used in case I only have XLR cables?
I dont think so.
It would only output the input channels sent to the send/return effect and I thought that the mixer also needs the return connected to not break the path for that channels effects.
He2neg
Post by He2neg »
Take the Master2 Outputs.... or if possible a seperate signal from the Soundtechnican..
For the problem with cables get 2 cheap DI boxes (passive) and a short rca to 6.3m cable.
its not the best to use long runs of unbalanced signals so the di will be good in any case =)
~Berlin~
