[IMPLEMENTED in 7.22] Autopilot feature play next column
Id like Resolume to have the option to play the next column as an option when a clip reaches the end. Right now its only play the next clip and all the other layers are left in the dust.
Re: Autopilot feature play next column
No....
What if you have clips playing in other layers that are not the same duration. you would just abruptly stop those clips because another clip dictates it?
What would be the purpose to ask for this? There's probably a much easier solution to your scenario.
Yes....
The scenario is I make all my own content, everything is exactly the same length. I layer motion backgrounds (Layers with a 1 second transition) with Alpha sequences. Ive been creating content for large scale corporate events on D3 and Pandora's Box for years and Im starting a Resolume solution for events. Im excited about what Resolume can do, but im trying to suggest features that D3 especially has that can be implemented in Resolume.
Thanks for the suggestion!
I think we had this come up already a few times.
viewtopic.php?f=12&t=15234
viewtopic.php?f=12&t=19383
viewtopic.php?f=12&t=13326
search.php
search.php
You can't really compare Resolume to D3, they're two different things. If I want a timeline based system I'll use D3, For everything else I do (99% of my work) I use Resolume. The feature you're asking for might work for you, but probably will cause more trouble for the other 99% of the users. I'm trying to look at the bigger picture hereIntange wrote: Fri Jan 24, 2020 02:42 Yes....
Yes , I know they are different, but its amazing how close I can get Resolume to work like D3. I am just asking for the option to play next column as well. It doesnt mean you have to use it. The way I use Resolume is different than how most people use it, but it works so well and easy to program and control, way better than D3
If you wanted to, in the meantime, I could write you a TD app that will do this. How would you want it setup? When a specific layer's clip end's it triggers the next column? Would this be for every clip or just a select few?Intange wrote: Fri Jan 24, 2020 16:51 Yes , I know they are different, but its amazing how close I can get Resolume to work like D3. I am just asking for the option to play next column as well. It doesnt mean you have to use it. The way I use Resolume is different than how most people use it, but it works so well and easy to program and control, way better than D3
If you make your own content, why not combine all the layers into a single large file, adjust your comp size and map accordingly? This also prevents content drifts (and a workaround for LTC sync)
Thanks for your offer. My workaround right now is I wait for the clips to Autopilot to the next column and then I push the column. Matted clips are set to cross fade and "relative", so when i push there is no visible change. Its not a deal breaker but would love to have the system push automatically to the next column. It sounds like im not the only one asking for this so I'll wait. Thanks again.
Ok, if you change your mind let me know, I could knock that app out in about 30 min
+1 for this as well, and I'll tell ya why. Using the "loop on frame x" trick described in another thread, I can get a video to loop nicely, but then hitting spacebar restarts the column thats already looping. What? I have to find the mouse and fire the next column? I'm doing 2 other things already, this will deffo get fat fingered. Did I miss something?
