Datapath x4 to Black Magic SDI box weirdness
Digitrevx
Post by Digitrevx »
Hey, so I got a situation where I've got a Datapath x4 (DVI ver) having odd issues with 4 SDI runs.
Datapath
https://www.bhphotovideo.com/c/product/ ... html/specs
SDI conversion boxes
https://www.amazon.com/Blackmagic-Desig ... F7R9V5M9SY
I have 4 Single link DVI to HDMI cables going into each of these black magic boxes.
The odd issue is that at random I get flickering on one of the 4 projectors the runs are being sent to. If I swap that black magic box with Decimator and run it in interlace mode the problem run will start working..
Decimator
https://www.amazon.com/Decimator-MD-HX- ... P1JM4RCACY
So the question is why does this happen and why would running it in interlace fix it. Is it a bandwidth issue or a datapath issue??
I'm not sure if its a specific run issue if the flickering can happen on any of the runs every time I power cycle the datapath..
Re: Datapath x4 to Black Magic SDI box weirdness
How long are these SDI runs?
SAMOYO
Post by SAMOYO »
Hey there - I have a similar issue at the moment - would love any immediate help.
Setup:
4k Display Port out of GPU to Datapath x4 -->
Datapath input set to 3840 x 2160 Quads -->
Output quads set to 1920 x1080P -->
HDMI out of Datapath -->
Plugged into Blackmagic Micro HDMI to SDI converters -->
SDI runs direct to projectors.
I see signal, it operates very fast(especially over 300ft runs).
Issue:
Periodically one of the project signals will drop, or blink for .5-3 seconds. This happens randomly, but also when faster or colorful content is played back...it is not consistent though.
I have looped out a HDMI signal from the converter to make sure sure it is not the distance / projector. Which I can confirm, the issue happens on the hdmi loop too.
Hypothesis:
It is the BM Converters, which are made more for broadcast and they do not like the 1080P signal going into them. They automatically convert the signal, so I do not have discrete control on how they are doing the conversion.
The Datapath x4(which I am new to) can not send out 1080i.
Possible Soltuon:
Change out the BM converters for Decimators to control the output signal discretely and make sure it is 1080p OUT running down the SDI cables.
I am not savy with SMPTE / broadcast / SDI signal per se, so I am shooting a little in the dark.
Any help would be super appreaicted.
Thank you community ~
