Autopilot stops when switching decks
jrxc
Post by jrxc »
I'm using the latest version of Arena and when I switch decks, Autopilot does not move to the next clip. Here is a video.
Re: Autopilot stops when switching decks
I don't see any clips in your deck2 ;)
jrxc
Post by jrxc »
I added a clip to Deck 2. I clicked on a clip on Deck 1 and Autopilot worked correctly. I then switched to Deck 2. The clip on Deck 2 was triggered by Autopilot. I would think this is undesirable for most. I just want the clips on Layer 1 of Deck 1 to loop.
You can then either make the clips in deck 1 persistent, or just stay on deck 1. ;)
jrxc
Post by jrxc »
Got it. Yep those both work. Not the best for what I like to do though. What I like to do is have some images and/or videos looping before the show starts. It would be nice to be able to edit some things in Deck 2/3 while Deck 1 is just doing the pre-show loop.
He2neg
Post by He2neg »
jrxc wrote: Sun Feb 09, 2020 19:42 Got it. Yep those both work. Not the best for what I like to do though. What I like to do is have some images and/or videos looping before the show starts. It would be nice to be able to edit some things in Deck 2/3 while Deck 1 is just doing the pre-show loop.
For that case it would be the best you get the "loop" into 1 clip and let this play... But i know that its sometime not possible
~Berlin~
