Machine and GPU test - Urgent
fingers
Post by fingers »
Is there any way to test the FPS of our machine, without connecting it phiisically to all outputs?
I mean, I have to try my GPUs sending 3x4k videos and I can´t connect the 3 senders and mount all the Leds phisically, they are like 34 meters Long.
I have:
2 x 980Ti
Ryzen 5 2600 3.9
Mother MSI x470 Gaming pro Carbon/AC
RAM 16GB DDR4 SDRAM HyperX Predator 3200MHZ.
1T SSD RAID 0
boris.lema
Re: Machine and GPU test - Urgent
Post by boris.lema »
from my understanding, no. You just have to connect 3x 4k monitors to test it.
Its handy if you have a studio or office where you have some monitors with different resolutions available.
Thats why i installed 2x Full hd monitors and 1x 4K monitor. Because the average jobs i do are 1x 4K and 1x Full hd. Its handy to test and prepair everything at home...
These days a 4k monitor are not that expensive anymore.… i would buy some to test and prepair.
You can also use display emulators like this one if you don't have that many monitors available.
Just be careful that the specs in the description also say 4k 60Hz ;)
fingers
Post by fingers »
Thanks, Boris and Zoltan.
I´ll try to get one of this options.
Martin
