Calculating Video Resolution
le095_arena
Post by le095_arena »
Hello Guys,
I have a thing that everytime makes me goes crazy.
For example, i have a 18 Meters X 5 Meters round surface to project, and i'll use 3 projectors 1280 X 800 native resolution. It's like a big cylinder, and i'll project from inside.
My question is: How can i calculate the resolution for the video content to create?
Thank you for your help :D
Re: Calculating Video Resolution
How many pixels of overlap will you have on the blends?
le095_arena
I don't know how to calculate it :roll:
elgarf
Post by elgarf »
I just doesn't care about blend overlaps, etc. In real world your projectors can be aligned a bit differrent, there can be differrent distances between them and projection surface, so you never make pixel-to-pixel content.
So, I get pixel/meter value and then just multiply meters to this value.
If you make panorama 18x5, projectors with 1280x800 native resolution, then 800px/5m = 160px/m. So, resolution will be 18m*160px/m = 2880px x 800px.
You can take 1280px*3/18m as base, but it's not necessary. Because even 2880 x 800 will be a bit bigger resolution, than you get as result.
In this example, since you're doing projections on the cylinder, you would calculate the blend overlap width as follows:
((1280*3)-2880)/3=320
Since you would have three blend areas.
For a regular screen, you would divide by two which would be the number of Projectors -1
If you look at my Vimeo channel, you will find a tutorial on how to do a 360° blend using the advanced output.
Snoxxx
Post by Snoxxx »
