ignore column trigger bug with shortcut
Julien-Robert
Post by Julien-Robert »
I'm using ignore column trigger On on one clip. It's working as expected when I click with the mouse on the Next column trigger button. But it's not working (the clip goes out) when I use a shortcut on the same button. Is it a bug or I did something wrong?
using Arena 7.1.0
10.14.6
Re: ignore column trigger bug with shortcut
Julien-Robert wrote: Thu Feb 20, 2020 17:04 I'm using ignore column trigger On on one clip. It's working as expected when I click with the mouse on the Next column trigger button. But it's not working (the clip goes out) when I use a shortcut on the same button. Is it a bug or I did something wrong?
using Arena 7.1.0
10.14.6
Would putting the ignore column trigger flag to "On" on the layer level work, or do you just want it for specific clips in that layer?
Julien-Robert
I want it for specific clips in that layer.
Do you have ignore column trigger enabled for the clip you want to keep playing, or the next empty slot?
Julien-Robert
The next empyt slot. Like I said, the function works if I click with the mouse on the button but not when I use a key shortcut. I didn't try yet with OSC or Midi.
Hmm, works fine for me.
Could you attach your composition and shortcut preset zipped, so we can take a look?
Julien-Robert
Here is the composition and the shortcut preset. The bug is in group called Debussy, on layer 1, column 2-3. Strangely, it works as expected if I put the clip on layer 2. So here is my solution, using layer 2 instead of 1. It just doesn't make sense.
When it doesn't work, the clip doesn't stop but restart.
Shortcuts.zip
(9.29 KiB) Downloaded 394 times
Column 2 clip slot in this composition in Debussy, is empty, it's not set to Ignore column trigger.
Can this be the issue?
Julien-Robert
No the problem is between column 2 and 3. The clip Debussy2.2 restarts instead of keep playing when pushing W key (the shortcut to trigger next column).
I think the project I gave you was not the good version. And I can't upload attachments on the forum because of an error. You have to drag the clip Debussy 2-2 on Layer 1 to reproduce the problem.
Work fine for me too. I let the clip play to the end so it's paused at the end, then launch next columns, clip stays paused.
Could you please make a recording of what happens for you?
