Spout receive problems
dep
Post by dep »
Hi all,
I am trying to send a texture through Spout from vvvv. This has worked perfectly in the past. Now, however, it does not!
When I direct my texture to the Spout sender in vvvv, I get the corresponding Spout source in Resolume under the Sources tab. But, when I drag it to a deck and assign it to a channel, it's only black. Also, to begin with, the Spout server source in the deck has a blue droplet icon, but when I click it to assign it to a channel, after a while the icon turns gray. And, in the clip properties tab, the texture dimensions are wrong (not what is being sent).
Another case of a spontaneously arisen problem - it used to work just a few days ago, with these same patches & compositions etc!
My Resolume version is 6.1.4.
Re: Spout receive problems
Are both programs running on the same GPU?
