Multiple mask on slice screen
AnnonymusGuy
Post by AnnonymusGuy »
Hi guys!!
In the coming days, I'll be working as VJ Guest on an event, but I have this particular Pixel map and I would like to make every kind of Hexagon, someone could you explain to me how to do it, please? :D
Cheers!
Re: Multiple mask on slice screen
https://resolume.com/support/en/input-maps should get you started, and Input masks could be also helpful: https://resolume.com/support/en/input-s ... lice-masks
Also check out the Cheat slices part in this video:
AnnonymusGuy
Solved!!
The guys of the event send to us a second-pixel map where the slices have the correct mask.
