SMPTE not working
rawdesigns
SMPTE not working
Post by rawdesigns »
I’m having trouble getting SYMPTE activated in Resolume 6 & 7. I’m using a headphone jack to USB dongle to send the signal and when I go to set it up in the audio preferences, as soon as I pick an input channel, the audio output and input devices reset back to default. I think it might be a Windows 10 issue but can’t seem to find a fix. Please help! Video below to show what’s happening.
Re: SMPTE not working
It's possible that Resolume doesn't have access to the microphone, you can check this in the Windows privacy settings. https://resolume.com/support/en/audio-input-no-worky
Another possibility is that the microphone is set to a different sample rate than your output, you can check this in the audio device settings for the microphone input.
