Resolume 7.1.1 & 6.1.5: Bug Fixes, Alley Trim, New & Improved Blends & Transitions, New Denon DJ Hardware
Fixes Fixes Fixes
Here you go, Resolume version 7.1.1. This version took a while and was a lot of work but it has a fix-list longer than The Return of the King's end credits. Including a long standing crash that happened on NVIDIA videocards after running Resolume for a few hours. Unfortunately we had to remove the GPU meter from the statusbar for now, we hope to bring that back in a future update. At least the crash is fixed. We're confident that this release will solve the last stability issues in version 7 that some of you have been experiencing.
New in this release are Dissolve, Exclusion and Overlay blend modes and there are a few new "50" blends like 50 Dodge and 50 Burn. Subtract, Difference and Difference I (inverse) have been improved and now look exactly the same as in Photoshop.
You can now use any blend as a transition between clips and it will always fade smoothly from clip A to clip B. No more unexpected results when a clip contains alpha.
Alley Trim
You can now trim a video with Alley! Set the in and out points on the timeline of a video, convert, done, your video is now trimmed.
Denon DJ has just released a boatload of new hardware and version 7.1.1 ensures all that hardware and new firmware plays nice with Arena.
Avenue & Arena 6.1.5
Since many of you are still using v6 we decided to release one more update. This version fixes a crash with the Shaper effect on macOS Catalina. NDI output is now compatible with version 7 (and other applications) by fixing the alpha channel and the latest version of Alley is now included in the installers.
Avenue & Arena 7.1.1 Fix List
#13620 Running resolume for long, FPS drops and content starts to flicker, Resolume crashes in the nvidia drivers
#13668 Crash on startup with 4G usb device
#12130 Crash with Denon StagelinQ, loading a track that has not been analysed yet
#12512 Renaming deck to empty name, makes other deck disappear from list
#13477 ConnectSpecificColumn via DMX, doesn't select some columns
#13494 Connecting APC 40, changes Default shortcut velocity for new shortcuts
#13517 Toggling dropdown items with multiple midi shortcuts is no worky
#13521 Default clip play mode is not applied properly, clips revert to loop, from start on composition reload
#13542 Random BPM Distance should be a whole number when controlled via MIDI/OSC/DMX
#13577 Selection of Polygon Points, Input and Output Mask Points, are not restored on Undo/Redo
#13641 Play once and hold default is not respected importing new clips
#13658 Effect Dashboard Links stay Linked to Layer object after Moving effect to Clip
#13766 Dashboard Link positions not saved properly in Effect Preset
#13807 Undoing effect remove doesn't re-set Dashboard dial
#13665 Multiple MIDI shortcuts not working like multiple keyboard shortcuts
#13669 AV clip BPM transport BPM Sync is lost on composition reload
#13670 Notice new network interfaces in DMX preferences
#13674 Polygon slice drawing hint displays question marks in Chinese and Japanese
#13678 Text animator flashing
#13682 Renaming layer or column , leaving # to have the index, # gets replaced by the index integer
#13683 Mjpeg 60fps avi hangs Resolume on windows
#13688 Luma key blend mode's Smoothness Param is not saved properly
#13693 Clip Random Distance can lose the setting
#13704 Some mp4's converts to DXV with a weird frame rate
#13721 Crash adding effect from preview to clip or layer
#13736 Crash switching from an output with delay to another output
#13754 Midi output velocity settings are not visible for shortcut, when a mode change enables them
#13761 Can't change FPS setting for image sequence in Alley
#13795 Relocate button in clip panel no worky
#13814 OSC Operator arguments not working
#13587 Denon gets choppy after running for hours
#13855 Envelopes inside Radial/Liniar Cloner do not restart when clips are triggered.
#13701 Envelope preset gets wrong preview after changing it's name
#13825 B&W Layer blend, doesn't make layer B&W with Alpha below
#13571 Option to disable open composition confirm dialog via the command line
Alley 2.1.7 Fix List
#13546 Alley Conversion "DXV Normal Quality No Alpha" Preset not listed in the Manage Presets window
#13576 Alley: Remember last download folder
#13584 Alley extracts Larger than 4GB files corrupted
#13718 Alley custom sizes reset when you try to delete the values to add your own
Download
Select "Check for Updates.." in the Avenue or Arena menu and it will self-update. Or just head over to the downloads to get your download on.
francoe
Re: Resolume 7.1.1 & 6.1.5: Bug Fixes, Alley Trim, New & Improved Blends & Transitions, New Denon DJ Hardware
Post by francoe »
woooo, trimming on the alley! I was waiting for this day.
morymb
Post by morymb »
I've been exploring Avenue and am really digging this software. It's amazing!
For Alley, how does that work with 4k footage. My footage will be from a lumix gh4 set to cinema4 mode.
The files themselves seems super manageable across the adobe and media player gamut, but I'm wondering if rendering may be super slow when converting them on alley to a dvx3. Just curious if anyone has a similar experience with this?
The fact that Alley can trim clips has me thinking of kicking some other more popular subscription programs to the curb. I mean, fine, maybe in the doghouse out back, but no allowance.
morymb wrote: Thu Mar 12, 2020 18:04 I'm wondering if rendering may be super slow when converting them on alley to a dvx3. Just curious if anyone has a similar experience with this?
If the OS can play the files, I'd recommend just trying it yourself. That's the quickest way to find out how the performance is.
You can get the free Alley installer from our download page http://resolume.com/download
morymb
Post by morymb »
I actually did try it already and it was slow, but it's 4k so I expected some time for it to take. I guess I was just trying to gauge, or maybe fish for some info on converting speeds from Alley. But like you said, I've already gotten into the time wasting habit of procrastination and forum mining :lol:
Either way, the tools are tremendous. :!:
francoe
Post by francoe »
4k convertion seems pretty fast, try a 10sec clip, maybe is a bottleneck writing all that data to your drive. ;)
