Small loop instead a frame when SMPTE stops
rolysudest
Post by rolysudest »
HI.
I am controlling Resolume via SMPTE, from another device.
When a press stop on master device and no SMPTE signal is present, a small "loop" appears, instead a single frame stop.
Screen recording - below, in fb link.
Version: 6.1.2
OSX 10.15.3
I have updated to the latest (6.1.5), but the same issue.
Is there any way in Resolume to automatically switch on other layer (a photo) when smpte stops?
Could somebody help me? Does somebody knows this issue?
Thanks in advance!
https://www.facebook.com/groups/5854801 ... 631723277/
Re: Small loop instead a frame when SMPTE stops
rolysudest
Thanks, Zoltan!
It seems that DXV file is about 10 times bigger than my mp4 file. :)
Yes, it is indeed, but it works nicely with SMPTE ;)
rolysudest
Thanks again, Zoltan
The problem is that my .mp4 file has already... 12GB. :) Resolume is synced via SMPTE with an audio playlist - live band - (Pro Tools session - 5 hrs).
Is there any other way to solve this issue? Is is possible to automatically activate another layer when smpte stops? I know for sure this is possible (to start another upper layer) at a given timecode - but not sure if a "default" upper layer (as a photo or "paused" movie) can be be started when smpte stops.
I need something like: when smpte stops, movie to be disabled (M or V fader down or other way to off movie from the main screen in any way).
Best regards!
Yeah, that would be one huge file.
You could create shorter sections of the file as DXV, and then place the files into a single layer.
Set the offsets for the file to the position where they are form, and then use Midi notes from Pro-tools to launch the clips just in time: https://resolume.com/support/en/midi-shortcuts
Alternatively, to the Midi launching you could use this tool to do the launching for you based on the SMPTE signal: http://palffyzoltan.hu/?url=controller
rolysudest
Hi Zoltan
If I place many shorter clips in a single layer, with different offsets, can be they played automatically, without to be in the "current clip" window? I tested this and only the video located in the "current clip" window of the layer starts.
Launching the clips automatically in Resolume based on the incoming SMPTE is not possible in currently.
You'd need to launch clips either manually, or via a third party application as I described above.
rigid
Post by rigid »
Zoltán wrote: Fri Mar 20, 2020 09:56 Launching the clips automatically in Resolume based on the incoming SMPTE is not possible in currently.
Hi Zoltan, I finally made a forum account after years of lurking and searching.
I’m currently on tour and just finished programming a timecoded show alongside my LD.
Was very surprised to find that Resolume is unable of setting SMPTE triggers/shortcuts or triggering a clip when SMPTE input reaches that clip’s offset.
Does Resolume have any plans to add this in the future?
We'll see what can be done.
