Resolume 7.1.1 crossfader blend issue
UON
Post by UON »
This update broke something, I have all my background as A clips, and all my foreground objects (with alpha) as B. I would move the slider all the way to B to fade in my foreground clips with the background still running, but now moving the slider to B fades the background to black. I can't get the foreground fully at 100% opacity without blocking the background now, and I've tried changing the crossfader blend modes. I'm still new at this but I just want to add effects to foreground and background clips separately with both of them going at max opacity!
Re: Resolume 7.1.1 crossfader blend issue
Moved to separate thread ;)
Moving the crossfader all the way to B, should fade out A layers completely, so what you describe sounds like the correct behavior to me.
Could you please make a screen recording of this, so we can see your layer setup and what goes on?
UON
Post by UON »
See how the background is still there, and the foreground is at 100% opacity with cloner effects? With this new version of resolume I cant do that anymore, the background is either black, or if I move the slider the foreground blends with the background using whatever blend mode I have.
I just want the foreground layers with alpha at 100% opacity with their own sets of effects, and have the background layers going with separate effects. I use layer routers for the effects, the background layer router effects affect the clips on A and the foreground effect layer routers affect B.
Is there any other way to do this?
Sounds like a complex setup, please attach your composition, and describe which clips you play together that behaves different in 7.1.0 than 7.1.1, so we can take a look!
