Resolume Record Function
morymb
Post by morymb »
I want to be clear on the record function, and know for sure if it is designed as a dedicated real time representation of the performance, or just a quick-on the fly-looping tool to reimport quick visual sketches back in to the main line.
I had about 15 stacked videos with synched audio files in one single column vertically.
I used midi shortcut to solo each track. Then I just starting sequencing the tracks via midi solo and recorded it in realtime.
At first everything was FLYING. Fast, totally workable. My render outs were peach.
Then, after about 4 rehearsal runs without recording, things started to seriously lag, and my recorded files became the usual trash file. ie-SPED UP, OUT OF SYNCH, THen slowing down, etc.
Garbage.
I'm wondering, because I am naive about a lot of tech stuff, believe me - is there a cache that might be getting filled up, causing these performance/render issues?
At this rate, even if I COULD figure out how to get on eof those screen recorders to recognize my 2nd hdtv display as a record target, and not just a black screen with audio, it wouldn't matter because NOW the performance aspect of Resolume is shitting out..lagging, etc.
Cache issue? Any cleaning I can do for something like this?
Like I said, it was working like a charm, even with all those stacked column clips with effects dropped in and map[ped, and audio attached to each as a combined dxv3 file.
He2neg
Re: Resolume Record Function
Post by He2neg »
The record function is not a real record function for recording a whole show.
i use it for quick recordings for
stills (instead of screenshot the output)
loops of multiple layers ( i replace it then and save some space)
realy quick n dirty loops (i.e. i had a frind with a band need to have some visuall stuff for handing over aat a gig) i took theire logo and just had a few effects placed over it and recorded this (quicker then AE for me)
but i dont use it regular at all ;)
It was a time were the record function was limited to the free ram of your system, but when im right it was changed in version 7 and can be longer now.
If you want to record long and complex setups i would give you the advice to use a 2nd System for that.
you can send your composition either via a capture card or via ndi and network. This recording system dont have to be a full power machine ... as usuall try try try..
~Berlin~
morymb
Post by morymb »
Thanks for that!
You wouldn't happen to be aware of any capture software that would play nice with a win10 i7 32gb ram 8 core gtx880m notebook would you?
I tried OBS, but when starting the output record, it says my drivers may not be updated. This is after I rigged my integrated graphics as the main thing for OBS, just to get a visible target preview screen instead of black.
Try, try, try indeed! :lol:
He2neg
Post by He2neg »
morymb wrote: Sun Mar 22, 2020 18:29
Nope Sry.... i would need to search and try as well...
* anyone here * the class * ferris? * ...ferris??*
~Berlin~
morymb
Post by morymb »
"Frye?..."
That's cool, man. I think I may try and get the resolume rec out to function better by investigating my own set-up!
itsallgood1
Post by itsallgood1 »
Hi guys, I'm new here & to this & just researching requirements before buying & wanted to know if (I didn't want to create a new post) with Resolume I can record what for example a 10 minute creation (eg if I was to do a live video for a track or song & wanted to keep what I'd just done).
I can see this article - https://resolume.com/support/en/6/recording but I'm not 100% clear from it if that answers my above question.
Very many thanks for any input.
Appreciated.
If you're new to Resolume, I'd recommend looking at the current version's manual ;)
http://resolume.com/support/en/recording
Recording is improved a lot in v7, why not just give it a try to see what your hardware can do?
