Stitching audio and video
FractalMan
Post by FractalMan »
What's the easiest way to combine the rendered output audio and video together into a movie with audio? (Or export combined?)
Premiere or Final Cut, sure, but simpler?
Maybe a new feature?
Re: Stitching audio and video
How about recording them directly into one file?
http://resolume.com/support/en/preferences#record
sean121
Post by sean121 »
Final cut pro X can do that. Can't say if it is simple in there. But if you find it difficult you can also watch some tutorial online on the same.
Camtasia is good too but I am not sure if it has that capability.
resolumejunkie
Post by resolumejunkie »
LumaFusion
