Resolume 7.1.2 Released: Improved Gradient & Clip Transitions
Resolume 7.1.2 fixes a few bugs and crashes but also has a much improved Gradient that can now take a palette of multiple colours. You can now link layer parameters to the clip transition phase which allows you to make custom clip transitions from effects. Checkout the two videos we made for this release.
Improved Gradient
Clip Transition Phase
Download
Select "Check for Updates.." in the Avenue or Arena menu and it will self-update. Or just head over to the downloads.
Hot Fix April 21st
#14057 Resync button doesn't reset BPM synced video clip transport
#14063 Dial Range + Dashboard cause glitchy behaviour
Avenue & Arena 7.1.2 Fix List
#13832 Crash creating the 257th Lumiverse
#13917 Crash switching AV clip from BPM to Beats
#13949 Crash sorting midi messages
#13954 Crash creating shortcuts while target changed
#13961 Crash moving renamed effect
#13973 Crash switching columns while clip param envelope point contextual menu is open
#13986 Crash dropping source with BPM transport default to create new clip slot
#13821 Allow midi clock sync with no Clock Start command
#13959 Option to pre-fill delayed clones with transparent
#13895 Linear Cloner Tail Rotation not working properly
#13713 Alpha with Slice + inverted mask in Slice transform behaves incorrect
#13548 Color Hue at 360 shows magenta instead of red
#13710 Posterize is black at 0.0
#13645 Right Click Color to Reset it does not Reset animations of Sub Params
#13724 Show OSX Icons for Command, Shift and other Modifiers in the PopupMenu's instead of the words 'Command', 'Alt' etc.
#13728 I can't Clear a Clip that only has it's name or color set
#13782 Registration preferences screen is untranslated
#13823 Shift + moving end points for checkbox, and combobox params makes other end point flash values
#13837 Clip panel monitor shows the wrong clip when the panel is updated by layer select
#14006 Clip panel monitor shows previously selected clip on column launch
#13846 Layer and group parameter envelopes can get lost
#13898 New layers in groups only show up after selecting another layer or clip
#13960 Groups can break apart when dragging layers
#13901 OSC /composition/tempocontroller/tempo/divide and multiply f 0-1 tries to set BPM directly
#13950 Shortcuts get deselected when clips are launched via other types of shortcuts
#13936 Crop Effect with Jitterbug blend on composition before transform can cause crash
#13958 BPM synced Video clips load with 8 beats duration from v6 to v7
Alley 2.1.8 Fix List
#14025 Crash trying to convert this file on windows
#13537 Alley crashes on exit while converting
#13849 Reordering files, Drop targets in Alley have a very small area, makes re-ordering hard
#13850 Dropping AV and Audio only clip to Alley, AV clip will play audio only
#13852 Alley plays / glitches audio samples from files in multi selection on drop
MkUltra
Re: Resolume 7.1.2 Released: Improved Gradient & Clip Transitions
Post by MkUltra »
The new update seems to have broken all compatibility with OBS Studio for streaming, it can't see the Resolume Display window
What do you mean by "Resolume Display window"? Do you have an output active using the Output menu?
Also checkout this article and video on how to stream with Resolume and OBS
https://resolume.com/support/en/Streaming
He2neg
Post by He2neg »
Feedback to Clip Transition Phase:
Awsome. But i feel it can be very confusing when its not clear what layer effect does what. It may be usefull to have the effect inside the transiton area and not at the bottom with all the other effects.
I think about when i want to use the same effect as "normal" layer efffect and as transition effect... when they are collapsed i cant see which is which
I hope you understand what i mean ;) And yes i know i can move it ...but if its inside the transition tap it would be even better. Or maybe when i drop the effect inside the transition tap it automatic is wokring with the transition phase.
~Berlin~
Online
He2neg wrote: Fri Apr 17, 2020 16:12 I think about when i want to use the same effect as "normal" layer efffect and as transition effect... when they are collapsed i cant see which is which
Have you tried renaming the effects? (right click on the effect name)
He2neg
Post by He2neg »
True Rename can be used as this ;)
I still love my idea to drop the effect in the Transition area to have it respond to the transition phase.
~Berlin~
edwin
Post by edwin »
Adding it to Transition Area is indeed nice and i played with this option as well. But it would be harder to determine the order of effects, would for instance transition effects be applied before or after the other effects? Now you can mix and match.
He2neg
Post by He2neg »
edwin wrote: Mon Apr 20, 2020 13:59 Adding it to Transition Area is indeed nice and i played with this option as well. But it would be harder to determine the order of effects, would for instance transition effects be applied before or after the other effects? Now you can mix and match.
puh... there is allways a valid point why something is done as its done. :geek:
~Berlin~
Misskwi
Post by Misskwi »
YAY !!! Transitions, longer!! YAY Thank you ! (yes and more, yes :D )
