Syphon FFGL Plugin
VJaxx
Syphon FFGL Plugin
Post by VJaxx »
:geek:
Hello, so I recently updated to Arena 7 and all the old FFGL Plugins are not working :|
Does anyone have the updated link to download the UPDATED Syphon FFGL Plugin??
:arrow: Syphon Client.bundle
:arrow: Syphon Server.bundle
this is to use Syphon as an Effect.
Yes, I know Syphon is built into Resolume as an Output.
This is to use it as an Effect. like in the previous versions
anyone?
Re: Syphon FFGL Plugin
If you only need output, you can send Syphon output from a specific layer in the Advanced output without plugins.
Create a new Screen in the Advanced output, and route your layers to the new slice: https://resolume.com/support/en/slice-routing
Right click on the Screen on the left, and choose Syphon as output device:
Hope this helps!
VJaxx
Post by VJaxx »
thats a lot more work. the Syphon FFGL Plugin used to work as a charm. I just can't find the updated version to download
