preview monitor shows mirror effect differently
p8guitar
Post by p8guitar »
I wonder why the preview monitor shows the mirror effect differently than the output monitor (see screenshot). Is this a bug, or is there a logical explanation?
https://1drv.ms/u/s!AsNedAPvuG2thQaY2CS ... D?e=QgCUdR
Arena 7.2.1; Ableton Live 10.1.18 controlling Arena with OSC; Schenker W507 mobile Workstation: i7-6700 CPU @ 3.4 GHz, 32 GB RAM, 2x m.2 Samsung SSD 960 EVO NVMe, NVIDIA GeForce GTX 1060 6GB GDDR5.
He2neg
Re: preview monitor shows mirror effect differently
Post by He2neg »
The mirror is on clip lvl (do I see this right) and the clip is smaller then your composition.....
sooo do your layyer maybe (auto)-scale the clip to comp resolution?
What i want to say there are several steps were some scaling / changing the clip can happen after the clip lvl.. or two... layer & comp....
so when you want to test it take a clean comp and put the clip with effect inside and then take a look.
but still my guess is a layer scaling happening
~Berlin~
p8guitar
Post by p8guitar »
Yes, the layer is on clip level.
Hmm... the layer is set to the size of the monitor: 1920x1080 (16:9), with autosize = fit. the content has a 3/4 aspect ratio, size is 640x480. So the clip is scaled to the height of the layer. Apparently the scaling is done before the mirror effect is applied?
Even more confusing: When I move the transform effect (with neutral setting: scale = 100%) after the clip, the preview and the output match. ?!?
Maybe as a rule of thumb, it might be the best to place the transform effect after mirror (or flip, or vignette)?
Before Clip Transform the effects are applied to a 640x480 texture in this case.
After Clip Transform, you have a texture which is the size of your layer 1920x1080, and the effects are applied to this texture. This texture has a 640x480 sized opaque part in the middle, where you see the clip, the rest is transparent, applying a mirror to this texture, you also see the transparent parts mirrored.
Now, with layer sizing set to fill, you override the original clip texture size. I think the clip preview doesn't know this, as it's rendered separately, and that's why you see the difference in the effect after Transform.
