NDI Input for PowerPoint
endrju555
Post by endrju555 »
Hello!
I have a problem with Spout. If I'm right, I should install the Spout (I have 2.006) and it should be input in Sources panel in Arena. I don't have NDI servers (like in tutorials in Youtube). I'd like to use one layer as Powerpoint (or similar - OpenOffice Impress) input.
Is it possible? I can't find any good tutorial that is answering my question
Thank you in advance!
Re: NDI Input for PowerPoint
I'd recommend using NDI Scan converter to grab the Powerpoint output.
It's free, you can get it from Newtek: https://ndi.tv/tools/
Once you got the NDI working, you can just import into Resolume (6, and 7+) from the sources. https://resolume.com/support/en/NDI_inputs_and_outputs
