Need advice: simple reverse playback
Hey folks,
I want to achieve the following:
- Playback a clip reversed with audio as fast as possible with Resolume, without setting up anything extra after drag'n drop it into a clipdeck.
+ The clips should start freezed at last frame when it is triggered with the mouse.
+ Universal hotkey for starting backwards playback of any clip I dragged into the clipdeck.
+ The clips should play backwards and stop freezed at first frame.
optional:
Auto inserting of clips of an folder to a defined clipdeck
Not part of the solution should be an external controller. It will be a stand alone system operated by a customer...so is has to be easy and streamlined as hell :)
Best wishes
Re: Need advice: simple revers playback
Sounds like a job for shortcuts.
Mapping the same key or midi note to these functions on your Selected Clip, would take only a push to set the properties.
You'd need 2keys. one to set the clip to last frame, paused, play once and hold, (3 shortcuts)
another one to set playback to backwards.(1 shortcut)
Thanks Zoltan,
this will be the way to go! ....thanks for your advice!
Best wishes
