Resolume NDI to OBS Studio Glitches, Crashes and Colour Mismatch
JaymiM
Post by JaymiM »
Need some help here, been getting serious phantom glitches and total crashses when sending NDI from Resolume Areana to OBS Studio. The glitch accumlates in the Resolume Output and OBS Studio preview views and eventually spills over my entire desktop and then crashes my system. Also it seems the NDI output colour does not match source, like a forced dynamic range or something? Have checked every setting possible. Only potential suggestion in OBS log after areana.exe is "deprecated pixel format used"?
System:
Intel i7-6800k 3.4Ghz, 80GB RAM, 2TB SSD, Nvidia GeForce 1080 (8gb), Win 10 Pro 64-bit
Resolume Areana 7.1.2.69101
OBS Studio 25.08 (64bit)
NDI colour mismatch
NDI colour mismatch
glitch issue
glitch issue
glitch issue
glitch issue
glitch issue
glitch issue
Re: Resolume NDI to OBS Studio Glitches, Crashes and Colour Mismatch
How are the colors in Newtek NDI monitor?
How about RAM, and vRAM usage when the glitches start, are they also there in NDI monitor?
Does OBS or Resolume crash?
JaymiM
Post by JaymiM »
Same difference
CPU: 6-75%, RAM: 9-10%, VRam: 17%
Gliches present Resolume Output Monitor, Newtek NDI Monitor and OBS Preview.
Interestingly the NDI monitor eventually gets to a state that seem to flicker between conent and alpha
Glitches the propogate across entire screen and "x" but not fully quitting Reolume resolves them
Usually Resolume, but also OBS and if left unaddressed (see "x" above) the entire sytem crashes leaving only audio channel open.
NDI colour mismatch
NDI colour mismatch
JaymiM wrote: Thu May 28, 2020 15:36 How are the colors in Newtek NDI monitor?
Same difference
Same difference compared to Resolume or to OBS?
Sounds like memory/VRAM corruption to me, probably because of the two OBS instances. Or maybe overclocking?
JaymiM
Post by JaymiM »
Zoltán wrote: Thu May 28, 2020 17:52
Same difference
Update, can retract this one. Resolume NDI represent all colors accurately when casting original media over NDI. The colour issue above was when re-casting OBS NDI input. User error, doh!
Reduced entire set up to 1 x 4k monitor and only Resolume and NDI monitor - no other apps running. Running 6 layers of 1080p/60 RGB content (no aplha) with edge effect applied to each layer and also on comp. When adjusting the window size of the NDI monitor the glitch (transparency) occurs. Either crashses NDI monitor or entire system.
Hmm, maybe a few versions older Nvidia driver could help, or newer NDI monitor.
