RAM 40% empty composition
JALA VJ
Post by JALA VJ »
Hi good mornig
I use Resolume 7.1.2,
3 layers but a empty composition. the ram memory is at 40%, No effects, no clips...no output screen.
I do not get it, i restard the machine and the Ram is to 25%...
I use Resolume a long time this night, opened to configure the show but the problem is all night,
What is the problem?
I need a long time used for the show.
MacOs Catalina 10.15.4
Macbook pro 15" inch 2017
3,1 Ghz Intel Core i7 4 nucleos
16gb Ram 2133nMHz DDR3
Raedon Pro560 4gb
Intel HD graphics 630 1536 MB
1 TB SSD
BootCamp Windows 10
Audiovisual Technician
Led Screen, Projection, Watchout, Analog Way, Freelance. Edition and Postproduction with Premiere, After Effects.
M.B PRO 2017-15"-i7-3.1GHz-1 TERA SSD-16 GB RAM
M.B PRO 2010-15"-i5-2.4GHz-500 GB SSD+256 GB HDD-8 GB RAM
Re: RAM 40% empty composition
The number you see there is the total System RAM usage, not only Resolume. You can check the per app usage in the Activity monitor.
JALA VJ
Post by JALA VJ »
Okay, thanks for answering so quickly, I thought it was the Ram and Cpu that resolume used in its processes.
Thank you
