Live color detection triggering clips
Sam Verlen
Post by Sam Verlen »
Hello,
I have a live camera in input and I would like to be able to dynamically replace region with a given color (detected on the input stream) by a clip.
If this color area moves on the input stream, the goal would be to have the clip following the position of this color area and replacing it dynamically.
Any advise to do this with some plugins ?
Thanks for your help.
Re: Live color detection triggering clips
If you'd only like to play "through" a specific color, you could try the Chroma key effect on your camera clip, and play the replacement video on a layer below it.
If you'd like real-time movement tracking, you'd need to look for a third party solution.
