Memory leak resolume 6
polly_potb
Post by polly_potb »
Hi.
As soon as i open resolume my memory starts to rise and it keeps on rising until its 98%
my setup is
resolume 6
Asus b450-f and b450-i (both do the same)
ryzen r7 3700x
ddr4 3200mhz 16gb
rtx 2060
Re: Memory leak resolume 6
Are you using DXV?
Any Spout input or outputs enabled?
polly_potb
hi, yes i use DXV.
Found what caused the problem!!
I disabled MSI afterburner and it stopped it!
Hmm, weird.
Did Resolume use up all your memory, or was it Afterburner?
polly_potb
Resolume used all my memory, afterburner was in 0%
really weird but since i uninstalled it there has not been any problems.
I tried to reinstall it to be sure and problem reapeared
Yeah weird, I don't see any issues on my desktop with afterburner running.
Do you have the latest nvidia drivers?
