360 blend
melamedori
360 blend
Post by melamedori »
hello everyone. i am a teacher and all i need to do in my school is to Create a 360 degrees projection with 3 projectors. i am not going to be VJ. so, is resolume avenue enough for me or i need resolume arena ? where can i find documentation or video to learn how to do it ? thanks
Re: 360 blend
Edge blending is only available in Arena.
You can find info how to do it here: https://resolume.com/support/en/edge-blending
To create a 360degree blend you can drag the edges of the slices off the composition are in the input selection somewhat like in this video
Sadler
Re: 360 blend
Post by Sadler »
You can always hand craft your blend masks, and your projectors may have edge blending. A hand-crafted PNG won't be as configurable/editable as Resolume Arena but then edge blends won't change much in an installation.
Blusound
Re: 360 blend
Post by Blusound »
Zoltán wrote: Tue Jun 23, 2020 09:37 Edge blending is only available in Arena.
I think aspect ratio of the source will not manteined in this way
Re: 360 blend
Blusound wrote: Fri Sep 04, 2020 10:42 I think aspect ratio of the source will not manteined in this way
Why do you think that?
Blusound
Re: 360 blend
Post by Blusound »
Your input right slice is 400x480 which is a aspect ratio of 0.83 and ur output right slice is 640x720 which is an aspect ratio of 0.89
Re: 360 blend
Yeah, the short video is more about showing the concept, to drag the slice out to the left and right sides to create the wrap around blend.
Blusound
Re: 360 blend
Post by Blusound »
I tried to re-create your setup but with coerent aspect ratio without success. Can you please explain better the way to achieve an edge blending for a 360 projection setup with Arena?
Tanks a lot.
Leonardo
Re: 360 blend
This should get you started: https://resolume.com/support/en/edge-blending
Repeat for the projectors you have, and the last one/first one, is the special blend where you drag the input slice out of the composition sampling area, so it overlaps on the other side.
Blusound
Re: 360 blend
Post by Blusound »
Zoltán wrote: Sat Sep 26, 2020 19:06 This should get you started: https://resolume.com/support/en/edge-blending
Ok but what I don't understand is how to achieve that without loosing aspect ratio on the first and the last one slices.
