Black Magic DeckLink
B3ttsie
Post by B3ttsie »
Hey Guys,
Im am wanting to run 5 outputs from my GPU and wondering if anyone has used the Black Magic Decklink Cards to achieve something like that?
Cheers
deflost
Re: Black Magic DeckLink
Post by deflost »
Hello.
it works Fine. But it is Not syncted to the gpu Outputs.
r.h.
westfernsehen, leipzig
mwebb9413
Post by mwebb9413 »
deflost wrote: Fri Jul 10, 2020 12:50 Hello.
r.h.
When you say works fine, under what circumstances are you referring? I have now tried decklink with 2 resolume builds, and had fps drops over half the desired framerate. A 60 fps outputting at 15-20 at most. This doesn't happen when converting HDMI to SDI from the graphics card outputs. Any advice?
