Arena 7 not show Datapath capture card
kevin
Post by kevin »
Dear,
I have problem with Resolume Arena 7, I use HDMI capture card of Datapath, with version 6 still can detect it in Resources but version 7 nothing, I dont know why.
Anyone have same problem and fix it already?
Many thanks,
Re: Arena 7 not show Datapath capture card
Yes, it's indeed broken in 7.2.0, will be fixed again in the next release.
You can get 7.1.2 where it should work meanwhile, from the bottom of our download page http://resolume.com/download
kevin
Post by kevin »
Zoltán wrote: Thu Jul 16, 2020 10:10 Yes, it's indeed broken in 7.2.0, will be fixed again in the next release.
Thanks you very much,
I come back with 7.1.2 and now is OK.
Intange
Post by Intange »
What Datapath capture card are you using?
