Lost MIDI maps after installing resolume upgrade
BDH
Post by BDH »
Hello
I have a compositon of a live-show, fully automated in midi (led screens, pixel map,...).
Everything worked fine on the road with previous version, now upgraded to the last version 7.2.1 (21 july 2020) of resolume and it lost +-100 midi maps. From clips itself, select layers, choose color,...
Same when importing backup showfile from before the coronacrisis.
I'm remapping the midi now but lost a day by doing it and it's still not 100% ok...
Any one else had this problem? :(
Starting to perform again next week...
gr
Bart
Max OS High Sierra
Macbook pro 15 2018
2,6ghz i core i7
16Gb ram
Intel UHD 630
BDH
Re: Lost MIDI maps after installing resolume upgrade
Post by BDH »
update: midi shortcuts weren't loaded together with the composition, learned a hard lesson -> always save and backup your midi shortcut files because they get overwritten so easily as the default shortcut file...
The composition stores the currently active shortcut presets on save.
If you create a new preset, or decide to use a different one, then the composition needs to be saved too, if you'd like them to be loaded with the composition indeed.
