Fastest and reliable synch/trigger method ?
pyrodigy
Post by pyrodigy »
I can able to connect between two computers at real 2 gbps communication speed.
What is the fastest and reliable synch/ trigger method between them at resolume arena ?
Ndi, artnet, osc, spout..ext :?:
What do you use in applications where timing is critical ?
Re: Fastest and reliable synch/trigger method ?
Depends on the other gear you have.
I'd go for OSC, if you have a lighting console, go for Art-net.
