X1800 midi bpm sync issue
djwildfire
Post by djwildfire »
With the X1800 1.3 update I'm able to use usb to control resolume with it's midi function.
Everything is working great, except midi clock sync will either drop to 20bpm or shoot up to 500 bpm, after anywhere from 5 to 15 minutes, the only way to recover from that is to reset resolume. I'm on resolume 6.1.5
Re: X1800 midi bpm sync issue
If it was working before, it sounds like you need to contact whomever pushed out your usb update and see what they changed.
viewtopic.php?f=12&t=19468
This seems to happen when the incoming midi clock is not stable, could be the firmware change, or could also be that the USB bus you have it connected to is very busy, causing delays.
